Results 1 to 10 of 23
Thread: 2nd Gear drags before changing
    Mar 2009
    OZ
    A recon in the UK would cost £1K excluding fitting and you only get 12 months warranty. Thats more than mine is worth too. I've replaced mine twice with used units. The one thats in now cost £80 and its going strong. But its a lottery and you might want to consider 'going manual'. If so, there are some great write-ups on here. If you are in a gambling mood and decide to swap for another auto then I may be able give you some hints. Just one question - did the specialist give you the fault code from the tranny?
    Hi,
    no. he didnt give me an actual code. He just said that the transmission was slipping. i checked around and fitting a second hand unit is about 1400 with labour.
    Oldham, England
    Quote Originally Posted by dreman77 View Post
    Hi,
    Thats still about £700 and no guarantee. But if you dont feel up to swapping it or converting it to manual then labour is going to be a killer. Be interested to know what you decide
    Mar 2009
    OZ
    is it hard to change the tranny by myself? If I get a used one for about $750 then it wont be so bad. My mechanical skills are not that bad as long as I have a guide to follow and the proper tools.
  1. changing battery in key
    Last Post: 09-20-2009, 10:01 PM
  2. To anyone considering changing the gear linkage: DO IT!
    By NielsGalan in forum 5 Series BMW
    Last Post: 07-05-2007, 02:11 AM
  3. Replies: 2
    Last Post: 11-20-2006, 08:52 AM
  4. Changing differential gear ratios
    By lmcclain in forum 5 Series BMW
    Last Post: 04-22-2005, 07:51 AM
  5. changing engine fan on e28?
    By Celraysoda in forum 5 Series BMW
    Last Post: 10-21-2004, 04:24 PM
