Results 1 to 10 of 10
Thread: Changing differential gear ratios
    Apr 2005
    Philadelphia suburb
    Default Changing differential gear ratios
    I'm revitalizing my '95 540i 6-speed (I'm the orig owner) and am considering the diff gear change. Reading posts on the subject, it seems that most people just swap complete diffs, right? My car would have a 2.81 diff and I'm planning to follow the recommendation to go to a 3.15. I believe later E34 540i's with auto transmissions had 3.15 diffs, right? Are these diffs directly interchangable? Is there a better way to go?
    Quote Originally Posted by lmcclain
    Call Jim Blandton and have him make a chart for the different ratios. That is what I did. I cant remember what i went with off hand but the charts showed me the low end acceleration and the highway cruising RPMs. Very helpfull.
    Sorry but i dont have his number handy at work either. A lot of help i am!
    Apr 2005
    Philadelphia suburb
    Kent,
    Thanks for the lead. I'll try to track him down.
    Larry
    Quote Originally Posted by Kent Carlson
    Honolulu
    Default The input flange
    sometimes has to be swapped from the old to the new pinion.
    Other than that it usually goes pretty Mr. Miyagi like... Diff out....Diff on
    Apr 2005
    Philadelphia suburb
    Bob,
    That's exactly what I wanted to hear.
    Thanks.
    Larry
    Quote Originally Posted by Blitzkrieg Bob
    Tampa Bay, Florida, USA
    Ramon
    1994 540iA Nikasil EAT Chip
    Tampa Bay, Florida USA
    Apr 2005
    Philadelphia suburb
    Perfect. Not sure why I didn't find this before posting. L.
    Quote Originally Posted by MBXB
    you will want a 3:46 or a 3:64 (ratios might not be exact) I went with the 3:64 cause thats what was available at the time, I thought it would be too much but it isnt. I dont get any worse mileage on the freeway and the city is actually better. The difference in city driving is unbelievable and highway is same unless I want to fly. Top end is still unreachable with 3500rpms at 100 mph.
    Dayton, Ohio
    if your only at 3500 rpms, you've still got a long way to go before redline....
    Former: 95-530iM
    Current: 99 GMC Seirra 1500
    Apr 2005
    Philadelphia suburb
    Interesting. According to the upgrade info on E34.net, your stock diff was a 3.15, so you jumped quite a ways to 3.64. I was a little concerned that going from 2.81 to 3.15 would be too much. Thanks for the headsup.
  1. 2nd Gear drags before changing
    By dreman77 in forum 5 Series BMW
    Last Post: 03-30-2009, 04:41 PM
  2. Fluid for the 6 speed gear box and differential
    By yaofeng in forum 5 Series BMW
    Last Post: 07-24-2006, 10:04 AM
  3. 750i Differential gear question
    By grave77 in forum 5 Series BMW
    Last Post: 08-04-2005, 05:27 AM
  4. Replies: 4
    Last Post: 03-31-2004, 02:34 PM
  5. Rear differential gear oil ...
    By KurtM in forum 5 Series BMW
    Last Post: 02-19-2004, 10:57 PM
