Originally Posted by
tim eh?
actually, claude i think you're right...
battery is a 'moll' and less than a year old... have to get some more readings but it is now suspect #1. wish i had more gear but i only have a voltmeter and a booster pack.
...gotta get this tested properly... autolectra (where i bought the battery) won't do a load test unless battery is fully charged which means waiting for 4-5 hours with the battery out (doesn't end up higher than 12.5 no matter how many rpms i give it) and they are far.
can i borrow a battery from another car if the amp output is similar? i'm thinking i could compare symptoms or just use it to drop mine off if i can tie it down tight enough.
whacked Q: how 'bout my 700 amp booster pack? can it be used in place of the car battery just to test system voltage (ie engine running no driving) or is that just a recipe for disaster? so far i have restrained myself (think exploding acid everywhere...)
so sorry for the typical noob questions...
