I got that same separator from JC Whitney but I never got it to work. I run out of bolt before the ball joint separates. How do you make it work?
I don't understand how that thing work... they use the ball joint as an anchor and then pushes on the ball joint threads to pop it out?
Just a bit worried about your steering plate as Bentley manual says to tighten to 110Nm and to use loctite thread lock. Definately one part of your car you don't want to drop off! Great write up though!
Had to use blow lamp and BFH to get thrust arm ball joint off steering plate on both sides of my car
...and that's loctite 270 btw
Mmm... maybe that is what I did wrong... Got any picture of how you mount it so I can confirm what you meant?
