this works very well indeed!
Originally Posted by
RallyD
You need a lot of force applied in a brief instant to break it loose as it is a tapered (interference) fit. If not reusing the arm and ball joint the pickle fork/prybar method works but almost always rips up the rubber boot.
I back the nut off until it is flush with the end of the pin. Tap in the pickle fork to apply constant pressure. Heat the steering knuckle with a propane torch, expanding the metal, then give it a sharp rap with a 5lb mini-sledgehammer. Then have a St. Pauli while the parts cool off.
oh and wear safety glasses.
