Results 1 to 10 of 12
Thread: Green coolant?
    PA
    Default Green coolant?
    Ok I took the M60 apart this morning and got it back together. Just going for the t-stat for now since sister needs to get back down to NC soon and I don't have time to drop the water pump and all today. The coolant is actually green - it must have been watered down in the expansion tank as well as the expansion tanks color that made it look gold/amber. Its actually green. What should I replace it with?
    East Brunswick, New Jersey
    Green coolant.
    '01 540it, 6/01
    '03 325i 5 speed, 9/02
    '10 535ix. 9/09
    '10 mini 6 speed
    '15 mini countryman 6 speed
    just put water into it until you have the time to do the water pump.
    Sep 2007
    Seattle, WA
    True.
    You'll still have plenty of anti-freeze in the system to prevent corrosion over the short term (like a few months or so, maybe more). Topping it up with distilled water is fine for now.
    When you do the pump, use either the BMW blue, or that gold/amber stuff that was talked about in the other thread.
    Why?
    Because the BMW & gold/amber anti-freeze's are much more pure than any of the normal green anti-freeze types. Impurities will cause clogging and corrosion.
    Use the better anti-feeze's to prevent cooling system problems.
    PA
    Quote Originally Posted by bubba966 View Post
    True.
    Why?
    nah im anti BMW blue - its damaging to plastic, which mostly comprises bmw cooling systems.
    I got Peak long life green. Good to go. thx guys
    Sep 2007
    Seattle, WA
    Quote Originally Posted by Jon K View Post
    What info do you have the BMW blue damages plastic? I've not seen or heard anything like that before.
    And I do recall that the Peak anti-freeze was one of the more pure green anti-freeze's. So it's certainly a better option than most of them.
    Wellington,New Zealand
    i think the most important thing is you change it regularly
    PA
    Mr Winfred himself as well as my experience with broken thermostat housings or radiator necks - you can see how the coolant gets into the plastic
    Mar 2007
    Liverpool UK
    I get mine from the dealer, they say they only do one... It's Green?
    Default I've seen plenty of broken thermostat housings and
    radiator necks on cars that have green as well as blue. On my own i've used blue with no problems , no broken necks and no broken thermostat housings. I use prestone extended life on virtually all of my customers cars unless they specify something else. I usually ask them. Most of the older bmw's i see including e46 and e39's somebody at some point put green in and i've now been having good results with the Prestone long life ,all models all makes. Costco has it in a pack with 2gallon of unmixed antifreeze and 1 gallon of windshield washer bug cleaner or deicer. Its about 22.00 for the 2 pack or 11 a gallon each with a freebie on the bug cleaner. I've had good results on every car i've used that in .... in fact i'll probably change my own bmw's over when i do the next fluid change on them ...... maybe. My only rationale for not using the bmw is that its getting pretty prices these days... much more so than it used to be.
  1. Green coolant....prestone extended life??
    Last Post: 01-12-2009, 10:02 AM
  2. Replies: 8
    Last Post: 06-18-2006, 06:56 PM
  3. ::.. Green e34 1/43 scale... anyone?
    By Qube in forum 5 Series BMW
    Last Post: 12-23-2005, 06:37 AM
  4. Anyone else using the EBC Green Pads?......
    By MTMnet in forum 5 Series BMW
    Last Post: 01-23-2005, 10:41 PM
