Green coolant.
Ok I took the M60 apart this morning and got it back together. Just going for the t-stat for now since sister needs to get back down to NC soon and I don't have time to drop the water pump and all today. The coolant is actually green - it must have been watered down in the expansion tank as well as the expansion tanks color that made it look gold/amber. Its actually green. What should I replace it with?
Green coolant.
'01 540it, 6/01
'03 325i 5 speed, 9/02
'10 535ix. 9/09
'10 mini 6 speed
'15 mini countryman 6 speed
just put water into it until you have the time to do the water pump.
True.
You'll still have plenty of anti-freeze in the system to prevent corrosion over the short term (like a few months or so, maybe more). Topping it up with distilled water is fine for now.
When you do the pump, use either the BMW blue, or that gold/amber stuff that was talked about in the other thread.
Why?
Because the BMW & gold/amber anti-freeze's are much more pure than any of the normal green anti-freeze types. Impurities will cause clogging and corrosion.
Use the better anti-feeze's to prevent cooling system problems.
radiator necks on cars that have green as well as blue. On my own i've used blue with no problems , no broken necks and no broken thermostat housings. I use prestone extended life on virtually all of my customers cars unless they specify something else. I usually ask them. Most of the older bmw's i see including e46 and e39's somebody at some point put green in and i've now been having good results with the Prestone long life ,all models all makes. Costco has it in a pack with 2gallon of unmixed antifreeze and 1 gallon of windshield washer bug cleaner or deicer. Its about 22.00 for the 2 pack or 11 a gallon each with a freebie on the bug cleaner. I've had good results on every car i've used that in .... in fact i'll probably change my own bmw's over when i do the next fluid change on them ...... maybe. My only rationale for not using the bmw is that its getting pretty prices these days... much more so than it used to be.
