Results 11 to 20 of 23
Thread: One touch up/down all windows mod
    Dec 2006
    Quote Originally Posted by attack eagle View Post
    repent. your GM is broken... but enjoy it!
    i tried it today to make sure i wasn't - it seems as though i can do all 4 if i do the front two from the front, and the rear two from the rear simultaneously?
    otherwise i can only do the front two from the front simultaneously.
    Dec 2006
    That is normal, Charles. 2 is standard, the sunroof might be o.k. in addition, if the Amp in total for the GM is not to high, see my details above.
    @repenttokyo
    I only will believe it if I see that for real, make a video how you push with 4 fingers instantly all 4 switches and also with the other hand the sunroof switch. And then all should move at the same time.
    see my post below.
    Feb 2008
    Quote Originally Posted by repenttokyo View Post
    mine is the same - i used to be able to close everything by keeping the key turned in the lock position but since i changed my doors it doesn't work anymore
    Now I am confused. So you push the front 2 doors on the center console with 2 finders, and simultaneous you push the buttons in the rear doors.
    Then you need 3 arms
    1 in front center console, one right rear door, one left lear door
    Mar 2007
    Liverpool UK
    If I try to put the four windows up at once the car staggers the movement... Like if I leave them all down and use the remote it will start to close one, once that's about 1/4 the way up the next one will start to go up and so on.
    It's REALLY annoying when I've clicked my one-touch and then someone else starts to put theirs up and it stops my window.... Grrrrr.... I don't know why but it badly p*sses me off!
    Dec 2006
    Quote Originally Posted by 525i winter driver View Post
    my key thing works.
    Dec 2006
    i do occasionally carry passengers in my car.
    Dec 2006
    but not often.
    Apr 2004
    There should be a group of 3, 2pin plugs in the door. The yellow one deadlocks the car and closes the windows: It connects to a switch on the key barrel.
    I Just one one touch up and down on Drivers and Passenger windows - I'd have thought that would be quite easy to do?
  10. #20
    If it is that easy, just do it
    Remember, these connectors, microswitches etc. are all controlled by the GM.
    Otherwise we would not have made such a controller for the pass side one touch up and down function.
    So with the unit which we have developped you have the both front doors one touch up and down.
    That works since some years here in Japan. People want to have it because many E34 are in Japan LHD while the toll boths and parking ticket machines are on the RHD.
    But as some people on Bimmerboard absolutely want to have a 4 door one touch unit, we work on that now.
  1. Touch in/up paint
    Last Post: 07-05-2009, 06:02 PM
  2. Replies: 25
    Last Post: 09-05-2008, 11:22 AM
  3. upgraded GM which part # for one touch windows
    Last Post: 07-29-2007, 02:11 PM
  4. Bleeding the M30, did I loose my touch?
    By Bruno in forum 5 Series BMW
    Last Post: 12-06-2004, 08:41 AM
  5. All windows "one touch?" is it possible?
    By Jason in forum 5 Series BMW
    Last Post: 08-25-2004, 02:35 AM
