Originally Posted by
Ferret
Fault 1: Exploded radiator!
This turns out to be a symptom not a fault, unlike I first thought. Dismantled the expansion tank out of the radiator quickly and found a huge crack in the side of the radiator where the top expansion tank bleeder plugs in.
Quick trip to B&Q for some 5 minute epoxy resin and that problem's now fixed!
Got it all back together at the side of the road and the b*stards still overheating!
I *think* the _cause_ of all this trouble is that the pumps imploded - the radiator top hose gets boiling hot, but the bottom hose stays stone cold.
This implies that the thermostat's open as hot water's rising to the top of the system under convection etc. What really gives this away is that with the heaters on full, you get no heat and the hoses going into the firewall/bulkhead are stone cold... this indicates a lack of flow I think?
What do you guys think?
Going to tow the bugger home this morning and pull the waterpump and see what state it's in, I know the visco coupling is shot, but the lack of hot water to the heater is giving me that twitch!
