Results 1 to 9 of 9
Thread: a/c not blowing air
    Louisiana
    Default a/c not blowing air
    from fanatic jake dog, i own a 1989 bmw 525i that i bought about 6 months ago,when i bought the car the a/c only blew on the forth level i removed the a/c control switch and cleaned it out, the a/c blew on all four levels for about 1 day,after that it only blew on the highest level and after adding freon the a/c was cold,after a while the a/c did not always blow on the highest level it would only work at times now it will not come on at all, i can hear the a/c clutch engaging so i am fairly cofident that the switch is not the problem,if there is any help out there i would greatly appreciate it,is this problem the sword,the blower motor or could it be something else, thanks for any help that you can give me,fanatic jake dog p.s. were is the blower motor located
    Last edited by fanatic jake dog; 06-14-2004 at 10:19 PM. Reason: locating component
    sword
    ian w Guest
    I had the same problem, replacing the filter not only doubled the flow on full, but also the lower settings began working.
    I can't see a good reason why this fixed it, but it did.
    Default His car shouldn't have the microfilter.
    They didn't become available until around 1991.
    Quote Originally Posted by ian w
    I had a clogged filter on my 94 when I bought it. The fan still blew air but it was like the amount of air was off...on position 1 you could barely feel it, position 2 felt like what position 1 SHOULD have felt like. I'm with Jeff (and Dick) on this one, check out the sword.
    Quote Originally Posted by fanatic jake dog
    Jake Dog, I'll have to vote for the SWORD too. While there are websites that describe changing the mosfet transistors on the sword, which apparently is what usually fails causing the sword to either stop working or only work on one speed, I opted to just buy a rebuilt sword due to the fact I just didnt have the time nor confidence to try the repair myself and was told, and also read, that there was only about a 50/50 chance if success.
    There is a guy who sells them on ebay for a reasonable price and 2 year warranty. Check out item # 7905327462 on ebay and you'll see. When I bought mine I was like you and wasnt 100% sure it was my sword but he said if I bought one and it turned out to not be what I needed then I could return it for a refund and I'd only be out the shipping of about $6, I thought that was fair. He also walked me thru the install which wasnt bad at all and He'll also buy your defective sword from you too.
    There are a couple of guys on this forum that bought from him and were satisfied. Anyway I just thought I'd make you aware of a good source in case you choose not to try and fix it yourself. Good luck
    Baltimore, MD
    If your compressor is working fine then most likely it is your relay called a limit switch: http://www.realoem.com/bmw/showparts...68&hg=64&fg=45
    I replaced this and the A/C worked fine.
    Baltimore, MD
    Quote Originally Posted by fanatic jake dog View Post
    Yes it is the sword which is also called a limit switch on Real OEM:
    I Replaced that on my 1989 BMW 525i and then fan along with the A/C worked fine.
    Oldham, England
    There is something wrong with my screen. It says somebody posted a reply to a 6 year old thread. Should I inform Microsoft or get my mate Steve round? He says he works in IT but that seems to be a contradiction in terms
  1. Stop Blowing Me!
    By Flamin'Cow in forum 5 Series BMW
    Last Post: 09-26-2006, 04:12 PM
  2. still blowing hot air ....
    By RockJock in forum 5 Series BMW
    Last Post: 10-06-2005, 09:23 PM
  3. AC not blowing any Air
    By shokokoo in forum 7 Series BMW
    Last Post: 09-29-2005, 07:35 PM
  4. Air is always blowing!!
    By James in forum 5 Series BMW
    Last Post: 03-15-2004, 08:40 PM
  5. Air is Always blowing!
    Last Post: 03-12-2004, 02:35 PM
