M30 head bolt removal mystery--advice sought
Engine is sitting on garage floor on its bottom and mount leg.
I un-threaded the head bolts to the point (~1" out) where their grip threads should now be disengaged from the block. However, 4 or 5 of the middle head bolts are still very stiff & tight and will not disengage for withdrawal. Side load on the head should be taken by the dowel pins and by the strap attached to the overhead hoist, so side load should not be binding on these bolts.
What am I doing wrong? Why won't these bolts just get looser and come out like the others did? Nothing of this sort happened with other M30 head removals. At the end of a long day, I thought it best to get some objective advice before monkeying further.
Why not just remove all the bolts and knock the head off
with a rubber hammer. Why are you stopping after 1" out? After the bolts are out, the head will still be held in alignment with two guide rings I think on the 4th and 9th bolt (diagonal), so just rap it firmly with rubber hammer. I finshed my head rebuild about 6 months ago and my M30 has been running flawlessly.
I'd be glad to share some pics. Even the one were I gouged head surface during the install. Arrrrrrgh.
Any idea how much CCW torque you are applying?
Seems a stiff 20 to 30 ftlbs would be ok. Any higher and I might be scratching my head too. Keep us posted after you let'm soak for a while.
