How hard is it to remove and replace the head on an m50
Well I hear that replacing the head on a SOHC such as an m20 or m30 isn't that difficult because setting the timing can be fairly straight forward. Now I am thinking of perhaps reconditioning the head on my m50 at some stage. Is it a difficult job and do i need any special tools for setting up the timing.
I do have access to some extremely knowledgeable mechanics through my work as well as their tools so it shouldn't be too intimidating. I've always wanted to get into this stuff and now with the winter approaching here (read it will not be 40 degrees celsius during most of the day at work) might be a good time to do it.
I suppose the part that I am most unsure about is setting the timing for the DOHC after putting the head back on. What techniques are used for this?
I'm just finishing reassembly of mine after having a crack in the head repaired
The Bentley is very good for disassembly. Reassembly is a little trickier since they guide you to just after setting the VANOS timing and then give the ol "assembly is the reverse of disassembly".
One thing I did was take digital pictures at every step as I took it all apart so I would have a handy reference on putting it back the way it was. I didn't use any of the special tools and I found that there is a four pack of torx sockets available at Autozone for about $8 that covers everything you'll need for the job.
