Resistance value for the MAF
What is the resistance value of the MAF sensor for the M50TU engine? It is a hot film mass air flow sensor. Bentley lists the resistance value only for the M50 engine with hot wire sensor.
I think mine is dead as it is obvious somebody seems to have openned it before. But would like to be sure. I checked the voltage in the connector and I get about 12,30Volts in some of the pins.
Also, my thorttle position sensor resistance reads a range of 1,36Kohms to 4,22Kohms. Fine? Bentley gives values of 1-4Kohms but says it is approximate.
