Control Arm Question - aren't they all the same?
I want to get new lower control arms and upper thrust arms without bushings for both and press some polyurethane bushings in from www.gruntsbushings.com. With the bushing issue aside, the only other component that can wear out is the ball joint for the lower control arms and on the upper thrust arms, there's the balljoint and I don't know what else on that component.
Are Lemforder balljoints and the type / strength of steel or aluminum superior to say TRW or melye? Is it worth the extra cost? I'm not complaining about the cost to begin with.
I recieved this e-mail from Patrick from BMA
"The Lemforder control arms are better only because the boot on the ball joint is better and they last longer. Now seeing that you track car, you end up replacing the thrust arms almost once a year regardless. The lower control arms should last a long time. They don't experience the same type of strain. If possible you always want to use Lemforder as a general rule."
Did someone ask about Grunt's bushings???
Quote:
Originally Posted by infinity5
please let us know how the bushings work out. i've never heard anyone comment on their street use. I'd love more stiffness in the car and longevity in the bushings but i'm worried about noise and vibration.
I have them in mine, but can only compare them to life with worn originals :( However my Lower Contral Arms are in need of replacement, so what I feel now is not that good either. Once this is done will have all new, so can tell you the results. What I can say is the bushing look very, very solid. Mr Grunt is in Australia, and I got these bushings relatively cheap from local suspension shop, next door to the Australian Bilstein distributor.
I'll post a thread once i add the LCAs (mine are bad) so you can find out :)
:) GP
