---Hmmm, Zuberberfelt grease it must be, hmmm, remove not from rim...very important umm hmm.Originally Posted by Cactuar
Hey folks, major noob question here... Since it's winter and I'm kind of bored I decided to wash my summer rims (15" original basketweaves, probably going to sell them). There was a lot of what appears to be grease all over sides and back, what's that for? I didn't remove all of it (just some spilled over the weaves) in case it's necessary, but what's it for? Is it just grease the wheel guy puts to ease the tire installation process?
Thanks
Why is it important?
It's black and quite thick.
-Hmmm thought it has provoked for you i see, hmm simple grease it is, not strong with you the force. important it is to use, powers of thought you do have. practice you must to use this, ummmhmmm.Originally Posted by Cactuar
What the **** are you blabbling about? I said I was a noob and not very knowledgeable, hence why I asked. Forget it, I'll ask on another forum, thanks.
He's not a representative of the collective board.Originally Posted by Cactuar
Can you take a photo of the grease you're describing? Is it possible it's wheel bearing grease? Any weird noises in the front end?
Bill B.
95 525i
Yeah I figured not everyone is "special" on the forum
I can't check for noise because I haven't installed those rims yet (I just bought the car and they came with it, as a 2nd set). A friend of mine told me not to worry about it, that it is most likely grease used to make the tire slide better when installing.
Yoda... you rock my worldOriginally Posted by YODA 1
I miss my e34
