Results 1 to 4 of 4
Thread: I have an odd problem but.... NEED HELP
    May 2006
    Port Orchard, Washington
    Default I have an odd problem but.... NEED HELP
    Hi, I have an odd problem, yesterday I went to start my car a 98 740i E38 and I got a brief engagement of the starter but then clicks. I assumed by battery was drained but after significant testing of my battery including load tests etc. My battery proved out to be just fine. I also tried to jump start my car using the approved BMW process but with the same result, the starter would engage but not disengage without turning the flywheel and then it would disengage. After all of this I discovered that right after my initial attempt at starting I had no power to my car whatsoever inside the cab of my car. Meaning, no dome lights nothing to the ignition, no chimes etc. Initially, I suspected the starter but now I'm not so sure, because two trustworthy technicians that I have had work on my car said that a bad starter regardless of problems would not lead to lack of power mentioned above especially dome lights chimes etc. I also noticed that whenever I'm connected to another vehicle via jumper cables I have all the power that I mentioned I didn't have before. I'm now suspecting one of the relays that is above my battery which is mounted in the trunk might have an open in it, but I don't know which of the three is the main relay. There are three relays back there and two of them (light green) seem to check out electrically, one of them (dark green) does not and I think it may be my main relay, I've checked every connection I can put my eyes on and this seems to be the problem. Any experience that anyone has in this area would be appreciated greatly. It may just be simpler if I knew what each of the 3 relays (in the trunk on the starboard side of the car right above the battery) were for.
    HELP
    Great Britain
    It might be the fusible link - I'm guessing that these are the same on yours as on the E34. The fusible link is probably near the battery so might be under the rear seat.
    Have a look at:
    http://www.bmwe34.net/e34main/mainte...sible_link.htm
    The fusible link is next to the battery under the rear seat passenger side left hand drive.
    A black piece of plastic similar to the link as shown above.
    Check also all ground connections.
    May 2006
    OK, thanks I have it fixed now, it was simply a loose connection from the negative battery post to the frame, it hid itself well and took considerable wiggling to identify it. The fusible link in an E38 is very near the battery as well I believe and I looked it over, the battery on an E38 is in the trunk in the passenger side fender well behind a little door. THANKS, so if ever totally without power, check the negative cable good, first ever fix for me that cost ZERO dollars...........
    Scott
  1. Ignition problem or fuel problem?
    By xtmsports in forum 5 Series BMW
    Last Post: 03-22-2005, 07:30 AM
