Results 1 to 10 of 16
Thread: What's most common cause of rear end sag?
    Chicago
    Default What's most common cause of rear end sag?
    Every time I park I notice that my rear end is a bit lower than the front, especially when I see other e34s around in Chicago. Curious as to what may cause it and if a Sachs kit would alleviate some or most of this. I am not buying it solely for that reason but at 98K its due for some upgrades.
    Do you have LAD system at the rear?
    Melbourne, Australia
    Quote Originally Posted by rnrn
    Every time I park I notice that my rear end is a bit lower than the front...
    Hmmm... Maybe change your diet & try either Yoga or Pilates. If that doesn't work have all your friends recommend you for an "Extreme Makeover"... though I've heard liposuction bruising is a bitch!
    Good Luck and in the meantime try to avoid looking over you shoulders into the mirror!
    An ‘all-round’ tired suspension on my 525 caused the rear sagging you refer to. I believe the front springs force the tired struts upward. Tired rear springs exacerbate the problem by further allowing rear end sag and the geriatric condition. Eibachs and new Boges all around alleviated the problem. The rear end now sits slightly higher than it did before the 'lowering' and the car now handles much better and appears more balanced than before.
    My 2 cents,
    Dave M
    the rears normally sit higher in the wheelwell than the front, look at a few E34s before you jump to conclusions as I did after I first got mine.
    Wellington,New Zealand
    re wot jeff said,the rear seems to sit lower but actually sits higher than the front
    Gone but not forgotten
    Bellingham
    Quote Originally Posted by Paul in NZ
    As on most cars, the rear fender lip is lower than the front. It's not because it rides lower in the rear, it's simply a styling thing.
    Kingston, Ontario, Canada
    Rnrn, is your 540i an auto...if so, yes...you probably have sag-itis. Check out Bruno's site for "suspension upgrade" ideas.
    IMHO, nothing worse for an E34 that huge, gaping spaces above both wheels!
    Cheers,
    Duey
    1995 540i/6 Sport Pkg w/E.A.T. chip and Nikasil injection Duey's Gallery
    Evanston, IL
    Default Cellulite is the most common cause.
    Just kidding.
    Jul 2004
    Perth, Western Australia
    Default .......
    my wife reckons age + having children doesn't help...........
    Quote Originally Posted by pundit
  1. Replies: 12
    Last Post: 04-04-2010, 04:33 AM
  2. :: Common problems on the e39...
    By Qube in forum 5 Series BMW
    Last Post: 11-24-2007, 11:18 PM
  3. BMW common ECU failures
    Last Post: 12-05-2006, 01:37 AM
  4. common vacuum leaks on M50?
    By tpierce in forum 5 Series BMW
    Last Post: 06-18-2006, 04:07 AM
