Results 1 to 4 of 4
Thread: Help, Winfred; I am having trouble removing the alternatore and power steering pump
    Voorhees, NJ
    Default Help, Winfred; I am having trouble removing the alternatore and power steering pump
    Winfred,
    You have me instructions a while ago that would replace the oil cannister gasket and stop this oil leak that I have had forever. I have removed the air box, the radiator fan and fan housing, disconnected the negative terminal to the battery, and started to remove the cooling duct to the alternator. I have the top bolt on the alternator off but I am trying to find the bottom bolt and any other bolts that are holding the alternator on. I have removed the two bolts holding on the power steering pump but I can't seem to locate a third bolt. The Bentley manual is not specific to my 1992 525i M50 engine. I would appreciate any help or comments that you might have.
    Best regards,
    Al Gray
    Maybe a look on the explosion drawings of the ETK helps. Click on the picks to enlarge and see more
    http://www.realoem.com/bmw/partgrp.d...00&hg=12&fg=25
    Voorhees, NJ
    Default Thanks for the tip
    Shogun,
    Thanks for the link. I will check it out. However, I may still need some instruction.
    Al Gray
    baton rouge, loserana
    3rd 13mm bolt is going into the oil pan at the back of the pump
  1. Replies: 3
    Last Post: 01-01-2007, 05:24 AM
  2. power steering pump
    By innes in forum 5 Series BMW
    Last Post: 10-14-2006, 09:09 PM
  3. Power steering pump anybody
    Last Post: 06-12-2006, 06:15 AM
  4. Need advice on power steering pump
    Last Post: 02-27-2006, 01:06 AM
