Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: sway bars - if u have them, please recommend
  1. #21
    Central NJ - USA
    quick bump to add on
    after talking with AlanS about his sway's (RD)
    he mentioned that the rear links wear out
    in 15,000 miles...
    and for a $100 part, when the entire setup cost
    me $400 i think that is stupid...
    UUC supposedly has a fix for this, anyone try it
    yet?>
  2. #22
    Bellingham
    My Dinan bars use the stock rear links (which would be nearly impossible to wear out by design) - with a bolt through the bottom where the stock bar ends stuck through.
    I don't see the point of using such a complex heim-joint link to connect the rear sway bar. By eliminating the small amount of rubber in the stock joint you gain a tiny bit of stiffness, sure - but..
    Heim joints are for track cars. They're strong and they're precise, but they're open to the elements and aren't long lived if they aren't taken care of.
    Is there not a way to bolt to the original end links with the RD bar?
  3. #23
    NJ-USA
    Does any one know what type of links front and rear are used on the Whiteline, Susp. Techniques, Eibach or G-power sway bar kits - rubber dogbone, Heim joint, etc.? Do all of them even come with links? Are all of these bars adjustable? Just curious as this would obviously play a role in the buying decision? Thanks.
  1. To add Sway Bars or Not?
    By EngPhys09 in forum 5 Series BMW
    Last Post: 11-08-2007, 07:05 PM
  2. Where would you recommend buying upgraded sway bars from?
    By Bimmer Nut Ed in forum 5 Series BMW
    Last Post: 06-17-2004, 07:50 PM
  3. sway bars
    By panzershreck in forum 5 Series BMW
    Last Post: 06-11-2004, 06:39 PM
  4. 94 540 Sway Bars
    By bam7276 in forum 5 Series BMW
    Last Post: 02-22-2004, 09:01 PM
