Results 1 to 10 of 13
Thread: Heater core removal and reinstall
    Jan 2005
    Reno, NV
    Default Heater core removal help!
    I have a 1990 535. It have metal lines that come into the heater core (no plastic). When I removed the core I took the lines off the core, but when I opened the box with the new core, it included the lines. Now I have tried to fish the lines throught the fire wall, but I am having troubles, and if I am having this much trouble getting them out, what am I going to have putting the new ones in that are aready attached to the core?
    Second, Can I just use the old lines?
    Hope someone can help.......
    Stephen
    do the lines disconnect right at the core?
    Jan 2005
    Reno, NV
    Yes they come through the fire wall and right to the heater core. I just didn't know if I could disconnect put in new o-rings and reconnect and not have problems. I really can't see how to get the new core in wihteh lines connected.
    Boston & Attleboro MA
    Oh those things are a b!tch! If you think getting them out is tough... getting them back in is even tougher.
    On the inside of the car at the rear of the foot compartment there is a clip holding the lines right before entering the firewall, remove that. If you dont care to much about the old lines, you can pull them through and they will get mangled, pulling from the engine compartment.
    Trick is look very good at how they overlap each other, and when installing new ones theres a particular sequence which they need to be put back through the firewall. Sorry dont recall. But it's kinda obvious if you analyze the overlapping & twisting. But even then it's not easy, try messing around w/ certain ones being almost all the way to the core and others partially.
    I think the whole removing & installing the lines took me close to 2hrs. butmy car has 3 aluminum lines, yours has?
    Jan 2005
    Reno, NV
    They are the 3 aluminum lines. I tried pulling them back into the cab, but it seemed like something was holding them up. I will look for those clips tonight when I get home.
    How much more do I have to remove to get in to get the clips out or will I be able to see them? The other thing is do I disconnect them from the new heater core? And if I do, why could I just use the old lines?
    If you look close inside the engine compartment right at the firewall there is a bolted clamp that secures the three pipes as they penetrate the firewall into the engine compartment leaving only nipples where the hoses attach. It is much easier to install the pipes to the core/plastic manifold if you remove this bolted flanged clamp bracket inside the engine compartment...a single bolt. You want as much freedom of the pipes as you can get to strike the right orientation to the plastic piping and the single aluminum pipe that fits directly to the core on the left hand side as you face the core. A further tip is the left most flange is best "rotated" out of position with a long screw driver leveraged off the other pipes leading down to the core. This single finger flange at the LH inlet to the core has a small bolt on one side and a finger that wraps around the core on the other side which isn't obvious without close inspection. You must rotate that flange free after removing the bolt and this typically takes more than hand strength because by design there is a slight interference fit to keep the flange from leaking. Use a long blade screw driver instead of tearing up your hand.
    The other attached two pipes to the core/plastic manifolding is straight forward.
    Do not overtorque the bolts upon reassembly and re-plug the HVAC control unit back into the harness and drive the car before you put it all back together after you install your new core and bleed the cooling system to make sure it doesn't leak.
    HTH,
    George
    Minnesota
    George,
    That one is going into my E34 file as "George M's heater core removal tips"! Haven't had the pleasure of doing that fix yet. And I thought the E30 heater core/valve was a fun removal/replacement.
    Jon
    Hi Jon,
    There are a few tricks of the trade to that job. Also you want to be very careful not to lose the little nuts behind the core that secure the bolts on the front side. They are simply held into depressions behind the injection molded core header by gravity. I view the single bolt, finger flange on the left hand side aluminum pipe connection to the core as a bit of a design faux pas. Reading the engineer's minds, this is done due to packaging and quite frankly serviceability was too severely compromised...a D- design in other words. Jon if/when you remove this fingered flange, a trick is to bend the aluminum flange slightly back into itself for greater interference when you have it free from the core. That way when you rotate that flange back into position it won't leak which I believe is quite common when this job is performed judging by the design. As you mention about these cars....absolutely...the best stewards of repairing these cars are those that keep simple word files of tricks of the trade posted on this board.
    Good Luck with your core when you do it and post if you get stumped along the way.
    Use your digital camera every step to document everything so you don't get lost.
    George
    Jan 2005
    Reno, NV
    George,
    I hope taht you are still there, mine has three (3) aluminum pipes that run from the engine compartment, through the fire wall and two go into the top left side of the heater core and one goes ont he front of the heater core, just off center (I think). There is no plastic piping at all, just hte plastic on the heater core. Have you seen this set up before? I am not by my car so I am not sure if it is held in the same as you discribe. I am hoping that I remeber how everything goes back together, as i pulled it a part two weeks ago and have not been able to get back to it (not to mention that they had sent me the wrong heater core, the one with all three hoses attaching to the front).
    The one thing that I was really wanting to know is, is it really needed to put these new aluminum lines in or can they be reused and will it seal up to the core if I use them?
    Hope you can help or maybe someone that has had the same problem.
    Stephen
    Default I reused mine.
    I replaced the heater core in my 91 535 about a year ago. I looked at the Al tubes and figured they would be more trouble than they're worth to fish out then back in again, especially considering that the tubes themselves were unlikely to fail.
    Definitely replace the core and use the new o-rings of course. I think the o-rings are the parts that are most likely to leak anyway. Clean off the old tube mating surfaces, and if they are not bunged up from pulling the old core, I would just reuse them. My core did not leak after the fix, so at least one data point says this method is okay.
    In retrospect... I might even have tried just replacing the o-rings and not even the core, but getting to it is such a PITA (haven't tried the sneaky, don't-have-to-remove-the-center-panel method that others here have written up) that I figured I might as well replace the core while I was there.
    HTH
    - Robin
    Robin
    72 Chevy K10
    01 E39 M5
  1. Heater core removal with pics
    Last Post: 10-02-2013, 04:05 AM
  2. heater core DIY
    Last Post: 11-12-2010, 06:21 AM
  3. Heater Core
    By Golgade in forum 5 Series BMW
    Last Post: 02-27-2009, 10:41 PM
  4. What Heater Core do I have?
    By uflnuceng in forum 5 Series BMW
    Last Post: 12-07-2007, 01:52 AM
  5. And there goes the heater core...
    By Dan in NZ in forum 5 Series BMW
    Last Post: 03-02-2004, 04:59 PM
