Results 1 to 3 of 3
Thread: OT - Garage Floor Paint
    Austin, Tx
    Default OT - Garage Floor Paint
    Has anyone painted their garage floor with any of the 2-part epoxy paints on the market? Your thoughts are appreciated.
    Quote Originally Posted by DonC
    I painted mine with a Velspar 2-part kit found at Home Depo 4 years ago. I did it far outside the correct way, but I have had absolutely no negative effects.
    I painted mine when it was 'bout 39 degrees F. I would work better if you painted per the instructions (bout 70 deg. F). In addition, I just hosed my garage out to make sure all obvious dirt was gone. Did not acid etch or scrub... I added sand (part of the kit) to make it non-slip. I have parked cars in the garage since then. I have had no ill effects. It's so nice to just mop up an oil spill and not have to worry about stains. I have had absolutely none, and have no plans to re-do the floor as it has held up very well.
    There is an additive you can buy that contains little flakes for decorative purposes. I would avoid these, as any screw/bolt/nut will instantly be camoflaged. I was fortunate that someone pointed this out to me prior to my application.
    So, go do it. Mine cost 'bout $80 for everything, including a roller.
    uberhahn
    '94 530i 5-speed. The work begins...
    Apr 2004
    New Hampshire
    I'm sold! I was thinking about tackling the garage this spring. I've got a nasty little oil leak and it'd be nice to not have to worry about staining or making sure I park just right over the oil mats.
    Dennis
    Quote Originally Posted by uberhahn
    uberhahn
    '95 540i 6sp, uuc ssk, Dinan chip
    proud member of the nikasil club
  1. OT: Anyone painted their garage floor with epoxy recently?
    By DanDombrowski in forum 5 Series BMW
    Last Post: 12-06-2007, 12:09 PM
  2. mirror paint+body paint=no match
    By LAXman2205 in forum 5 Series BMW
    Last Post: 05-17-2006, 09:59 AM
  3. the 750 does not fit into the garage
    Last Post: 10-06-2005, 10:45 AM
  4. OT: my new garage
    By schnell944 in forum 5 Series BMW
    Last Post: 08-11-2005, 12:31 PM
