Thread: Help Seatbelt buckle is stuck!
    Default Help Seatbelt buckle is stuck!
    I was going about my daily routine and then once i got to my destination i tried to release my seatbelt by pushing the button on the buckle and low and behold it did not release!
    I am sitting here dumbfounded and smashing the button and trying everything to unlock the belt. No results from that. So I ended up doing some escape artist show like Houdini in a straight jacket. Now i have to do the same of getting back into my driver's seat later.
    What are my options to fix this problem.
    The same thing happened to me a couple of weeks ago, where the button would just not go down. I figured out that if you push rediculously hard with both hands it will release, after doing that for a week it just went back to normal. Very strange, havn't had any problems since
    Black/Black '90 535IM..... '65 Cal look vw bug
    Quote Originally Posted by casurfer911
    thanks i will try this i have been just rolling with the over the shoulder strap with me sitting on the lap belt thanks!
    Aug 2004
    what you do is try moving a seat and then belt will loosen up a little and you'll be ok
    or get a new receiver and put it in, they do wear sometimes with all the dirt and crap they ingest.
    hah i just did what casurfer911 did and that simply did the trick
    thanks for all your suggestions
    as for a new receiver i might check that later on since mine still works... again
  1. Removing stuck wheels+stuck lugnuts
    Last Post: 06-02-2010, 09:28 AM
  2. 535i - 1991 manual - seatbelt stuck
    By Thanos in forum 5 Series BMW
    Last Post: 08-07-2005, 06:59 PM
  3. Seatbelt buckle fix
    Last Post: 04-27-2005, 03:57 AM
  4. seatbelt buckle dis-assembly
    By Dash01 in forum 3 Series BMW
    Last Post: 04-25-2005, 04:16 PM
