Hey Damianoz,Originally Posted by damianoz
There is a way to bypass the power locks. I am doing this from memory and it has been a while but I think this is right. On the passenger door hold up the door handle while turning the key to the unlock position. I think this should do it. Another option is to take another fully charged battery and attach it with cables positive to the starter motor terminal and negative to the frame then use the power from this battery to open the locks. This is a little more bother obviously but if the first option doesn't work this one should.
Good luck,
Gordo.
