Results 1 to 3 of 3
Thread: Aux water pump repair
    Jan 2005
    Default Aux water pump repair
    Just to let everyone know........I think it might be possible to repair the auxilliary water pump. Mine has been leaking for a couple of weeks at the rate of a pint every couple of days, and I just got the nerve to take it apart to see what it is all about. Mine was leaking at the o-ring joint. I cleaned up all the parts and headed to my local hardware store and paid 47 cents for a new one. I used a little plumbers grease to lube the o-ring on assymbly.
    Well I just got through driving the snot out of the car (well I had to test drive it) and all seems well. NO LEAKS!.
    Good day,
    Chris
    Often the plastic breaks and water/coolant enters the pump motor area. That is usually the end of the story for the pump.
    Good Luck with your pump. Anyway, it is not that important, just makes the temperature inside the car a bit more stable when car runs at idle or when you have to stop at a signal.
    Replaced the one on my car last summer after 16 years in operation.
    It may rest in peace, has done it's job.
    Maryland
    Default Sometimes the coupling disbonds - fixable too
    The entire assembly is nicely made and easy to take apart (including the o-ring). On mine the magnet on the motor coupling disbonded. I bonded it back with the advice of an expert at our aerospace company ("use epoxy") and it seems to be fine in bench testing. Have not checked it in the car because I replaced the pump with a new one before disassembling the old one. I have no reason to believe it's not okay though.
    In my case I really noticed the lack of heat at idle when my aux pump failed.
    Z
  1. Water Reservoir Clogged, Water Pump Leaking?
    By kelhami in forum 5 Series BMW
    Last Post: 04-28-2008, 03:01 AM
  2. Small water pipe came out while doing water pump
    By merlin in forum 5 Series BMW
    Last Post: 09-27-2007, 06:11 AM
  3. Wtf?! Water Pump?
    By nirvana19 in forum 5 Series BMW
    Last Post: 09-23-2007, 04:47 PM
  4. think my water pump is on the way out
    Last Post: 12-14-2006, 04:56 PM
  5. water pump
    Last Post: 06-01-2006, 04:39 AM
