Thread: By the way Martin here's what i use to pull the cam seal on
    Default By the way Martin here's what i use to pull the cam seal on
    a 740 ....
    baton rouge, loserana
    looks more like a 240 with the front distributor, 94 and up 940 can have a front dist but they don't have the low side ac line across the valve cover
    sears has a ok seal puller for 10 bucks, it's a little too thick but after you grind a few rch's off it works good, i've broken a few hooks on those when they stick bad
    Default My mistake Winfred, you're right , that pic was from a
    240 i was doing... I still use the same tool for a 740 though
    I have one of the sears seal pullers with the little half moon tool bit end but for some seals i like the windshield tool better...
    not the long flat handled half moon looking thing, the one i am talking about looks like a screwdriver with a slightly bent tip and a notch on one side with a red handle
    Default My seal puller was way too big for that job.
    I ended up with a pulling technique, of pushing 1 side in a bit. This allowed the opposing side of the seal to come to, as it were.
    Thanks again. There's great room to wrench on those volvo's. I was even impressed with the exhaust on the 740. The 4 into 2 downpipe went into a decent size single pipe catalytic. It looked stock & light.
    erased due to slander
  1. :: Aston Martin DB7?
    By Qube in forum 5 Series BMW
    Last Post: 07-31-2007, 02:13 AM
  2. Martin / others with an oil cooler...
    Last Post: 06-03-2006, 07:12 PM
  3. Martin - you got the wrong car...
    By Jeff N. in forum 5 Series BMW
    Last Post: 07-19-2005, 09:54 AM
  4. OT aston martin
    By infinity5 in forum 5 Series BMW
    Last Post: 12-13-2004, 03:46 PM
