Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Does anyone have any power seat info?
    Jan 2005
    Sicily
    Default Does anyone have any power seat info?
    I need the schematics on the drivers side seat, all the wiring and such underneath the seat, why the connector harness is different from pass side seat, and which wire is power on the seat? Please help before i give up on my project
    I had to fix my driver seat backrest for my 92 525i so I went to the BMW dealer
    parts dept and asked for a schematic printout of my seat. They can print you one
    there. I threw mine out for some reason. Whats wrong with your seat?
    Default What happened with the instructions I gave you ...
    on your previous post. (see link).
    http://www.bimmer.info/forum/showthr...5515#post55515
    If you agree, I can e-mail you pdf drawings for 1989 e34.
    Javier
    Jan 2005
    Sicily
    Instructions were fine, but i have no idea which wire is the power wire under the drivers seat, the harness from my car, and the one under the seat are different, the seat one is black and smaller and dfiff size than the white one that comes out under my carpet, we ran new wire made a fuse holder, pass side is good, driver side wont power up, i m lost.........
    Default Don't panic, got you have memory seat per the ..
    other post. Will try to work something for you today.
    IT IS NOT PERMITED TO GIVE UP.
    Javier
    Jan 2005
    Sicily
    Ok i will wait patiently, the seats are getting impatient though they need a new home, i rescued them from the junkyard , i just hope there is someway to bypass the memory and just have the power only if thats what is missing or in the way, thanks
    Nov 2004
    Default prob with the seat
    the seat of my car when u attempt to recline it tilts only on one side...
    the whole back rest doesnt go down only the left side... thus a weird position... how do u correct this?
    is there a picture of how i can fix the prob? i think it has something to do with the internal gears of it
    thanks
    Default Check these links. ...
    Default Please let me know if you do have the ....
    memory control module in the M5 seat you get as replacement, as indicated in the picture?
    If you do not have a connector to match the black connector under your carpet, then I guess somebody pull out the memory control module, or the harness going to that white connector, and who knows what else.
    Then, I need to know also:
    Do you have the harness and connector plugging into the adjustments switch (Seat control switch) module (X603, 12 pin black connector)?
    Do you have the harness and connectors plugging to each motor (X726 2 pins black, X727 2 pins white, X728 2 pins white, X729 2 pins black, X731, 2 pins white; 5 motors, X731 inside the seat back)?
    Javier
    Last edited by Javier; 01-28-2005 at 04:39 PM. Reason: Correct under the carpet connector color
    Jan 2005
    Sicily
    How bout this ill take a pic of the seat and show u what i got, cause u are getting too technical for me, im not good at this at all
  1. Help need power seat switch
    By kick7ca in forum 5 Series BMW
    Last Post: 09-04-2006, 04:02 PM
  2. Power seat...
    Last Post: 02-26-2006, 09:51 AM
  3. Power Seat Fixable?
    By maestronomer in forum 5 Series BMW
    Last Post: 04-25-2005, 08:26 PM
  4. Power seat trouble
    By casurfer911 in forum 5 Series BMW
    Last Post: 06-24-2004, 09:25 PM
  5. Driver's Seat Power
    By andyman32 in forum 5 Series BMW
    Last Post: 04-16-2004, 02:13 PM
