Results 11 to 20 of 22
Thread: Does anyone have any power seat info?
    Default Go into chat???
    Picture sounds great.
    Default OK e34it, this is what I’ve found up to now …
    When your removed the seat from the M5 1995, you were forced to leave in that car the Memory control module connector X18322 (Black, 26 pins), and connector X18323 (Black, 4 pins). One of them had attached wires going under the carpet, to connectors in left and right kick side panels, just ahead of the front doors, and the other, had a brown/orange wire bolted to ground under the rear seat. As you did, you also leaved the male half part of connector X275 (Black, 12 pins) wired to those fore mentioned connectors, this was the mating part for the connector under the carpet, at driver’s seat of your 1989 E34. You probably have hanging from the seat the male half of connector X626 (Black 8 pin), the female half went away with the X275 male half. This all suppose you did not cut any wires.
    If you look at your new seat, you should have a black box (Memory seat mirror control module) showing two missing plugs (X18322, and X18323, total 30 pins). In these conditions, to keep the memory feature for the seat requires to connect to those pins without the proper connecting plug, which, though possible, is some how complicated. The handicap I see here is that you are missing all the Mirror control devices. The mirrors control switch is a special one, and also the mirrors themselves are special. My concern is how will the system behave if he found no feedback signal from the mirror position indicating potentiometers. I do not want to bias your decision, but would be much easier to remove the memory feature from the seat and convert it to a plain power operated seat. I wouldn’t do it, but rather go for the mirrors, the mirror switch control and all the missing harnesses to complete the system.
    Let me know what you want to do. If you decide to bypass the memory, I can prepare you a detailed chart for wire cut and splice. The only limitation will be the connection to your existing connector under the seat; I wouldn’t like to cut the wires going to it, to splice them into the seat wires, as you will not be able to unplug them when attempting to remove the seat for maintenance/cleaning purposes. Think the best chance would be to obtain a male/female up to eight (depends on the seat features) wires connector and replace the existing X275 under the seat. Also let me know if the seat has thigh support switch, lumbar support switch, and heater switch.
    Javier
    PS: Haven’t seen any pictures yet from under your new seat.
    Jan 2005
    Sicily
    Javier here are the pics sorry i posted them at the top also, i dont care about the memory functions, i just want them to power up and move, i am the only one who drives it so memory isnt important, i already have power mirrors, is that the mirror stuff you are talking about? they dont seem to be related to my seats. Seat pics
    Default When you have memory power seats, ...
    the system also adjusts the L & R door mirrors according to the driver’s selection. Then, the mirrors not only have motors, but a position sensing potentiometer. Saw you did cut some wires, so it is hard to know details on what’s left on the memory system.
    To convert the seat to a standard power seat, you will require the “Seat control switch”, the one at the side with levers to control seat position, the connector to it, named X603 (Black, 12 pins with the shape of the attached picture), the motors, and the connector to the motors (black and blue connectors, 2 pins each plugging in the different motors). In order to permit the seat to be removable without cutting any wires, we will also require a male/female connector, think your female connector in picture 010 match the male connector in picture 006, we can use those to plug/unplug the whole seat, just like you did (I guess) with the under carpet connector at passengers seat.
    Once modified, the harness will look exactly like the harness on you passenger’s seat, so you will always be able to use that one as a reference. Let me work a little bit on the char to post it for you.
    Javier
    Default Here are conversion instructions ...
    Do not hesitate to ask for clarifications or further instructions if you find any discrepancy. Remember I'm using drawings and manuals, not the actual seat.
    Javier
    Edit: Links to missing pictures
    http://www.bimmer.info/forum/attachm...ntid=774&stc=1
    http://www.bimmer.info/forum/attachm...ntid=775&stc=1
    http://www.bimmer.info/forum/attachm...ntid=776&stc=1
    Attached Files Attached Files
    Default One more picture ...
    This is the tool used to remove circular metal terminals from the connector plastic body.
    Javier
    Default How is your seat conversion project?
    Jan 2005
    Sicily
    At a standstill, i have my friend working on the drivers seat, and worst case scenario im going to get an old power passanger seat, and switch my seat onto the rails to make a new drivers seat with pass side wiring components , and change the controls to the other side being the harness would be the same if i did that, let me know what u think?
    Default If you can put your hands in an ...
    old Driver's or Passenger's power seat, just get the harness, it will fit straight to your M5 seat. Of course, you will leave out of the system the memory specials, but the switch control and the motors will be on line.
    The harness will include connector X603 for the Switch control, connector X275 for the connection of the seat to the car, and the 5 small 2 pins connectors for the motors.
    Piece of cake.
    Javier
  10. #20
    Jul 2005
    New York
    bump because I'm sure this will come in handy.
    You're my hero.
  1. Help need power seat switch
    By kick7ca in forum 5 Series BMW
    Last Post: 09-04-2006, 04:02 PM
  2. Power seat...
    Last Post: 02-26-2006, 09:51 AM
  3. Power Seat Fixable?
    By maestronomer in forum 5 Series BMW
    Last Post: 04-25-2005, 08:26 PM
  4. Power seat trouble
    By casurfer911 in forum 5 Series BMW
    Last Post: 06-24-2004, 09:25 PM
  5. Driver's Seat Power
    By andyman32 in forum 5 Series BMW
    Last Post: 04-16-2004, 02:13 PM
