Tell me more about the CCM fix?
I just bought a new coolant sensor from Pelikan, usually use BMA, to hopefully correct my coolant light issue. My indy told me they found no error with the existing sensor or electical connections. They told me they have seen several cars with this problem. They suspect an electrical connection issue soemwhere in the wiring.
That said, your comments/fix are new to me. Can you tell me more about where on the ccm board the problem might be?
I plan to replace a problem dash bulb when it warms up a bit. This looks like the time to fix both issues.
Bill as usual, your knowlege is outstanding.
Originally Posted by
Bill R.
coolant sensors float stick at the bottom on me... I haven't had this happen with an actual bmw part only with the aftermarket ones like you get from Bma and other vendors.. If you still get the message after crossing the wires then you probably need to resolder the board on the ccm, check control module..
