Results 1 to 10 of 13
Thread: Are BMW engines "hemi's" :)
    Lexington, Kentucky
    Default Are modern M50-M60 BMW engines "hemi's" :)
    Technically, they are similar, yet more sophisticated, than the Chrysler Hemi engines. Am I correct, or am I missing something?
    Just a little triva/puzzler for the day.
    Default No, the combustion chamber is much closer to a modified pent than it is a
    hemi.... Hemi is a meaningless term that only describes the combustion chamber shape. It means that the combustion chamber is hemispherical in shape. Its no indicator of how sophisticated or technically advanced the engine design is.
    Lexington, Kentucky
    Default Thanks
    The sparkplug location is similar on both engines was the basis for my thinking.
    The chrysler hemi looks like this on my brothers donovan motor
    This is what the M50 head looks like, you can't tell it but the combustion chamber shape is different, even discounting the 4 valves instead of 2
    TE=Russell]The sparkplug location is similar on both engines was the basis for my thinking.[/QUOTE]
    Default If the Hemi used the current design
    of 4 valves per cyl., it would make much more HP and torque but in a smaller torque band. it wouldnt have the advantage of the 2 valve design "pulling" the charge through the chamber at high RPM's and that would make it a slug in comparison.
    Or something like that.
    One of the main things that distiguishes a hemi is its ability to breath. Notice in the picture that the two valves are 180 degrees opposite each other? They did this with two rocker-arm shafts per head, one for the intake valves and the other for the exhaust valves.
    Lexington, Kentucky
    Default Bill this great info-Thanks
    [/QUOTE]
    Kingston, Ontario, Canada
    Bill, do you have the pic of the guy that stuffed a feather through the ports on a Mopar hemi? It really shows the straight in/out geometry and breathing characterstics!
    On a different note, are the M60 pistons domed? If not, these engines wouldn't have a whole lot of quench...mind you, they are aluminum, which helps...
    Cheers,
    Duey
    1995 540i/6 Sport Pkg w/E.A.T. chip and Nikasil injection Duey's Gallery
    Central NJ
    Default "Hemi" in 2004 - more marketing than anything else
    Respectfully disagree, nearly any decent 4-valve design will 'breathe' better than a 180deg 2-valve.... The reason this hemi is 2v is either because of cost (it's cheaper) or because it does not particulary need to breathe that well. In it's current incarnation (5.7L 350? HP truck engine) it's built for low-end torque, not free-rev'ing HP. My best guess would be that the more restrictive 2V design gives higher-velocity exhaust outflow at low RPMs, yielding more torque. Cheaper is always a + at DC, too.
    Marketing gimmick. I'm pretty sure every manufacturer in the world are not scratching their heads and wondering "why did I spend all that money on combustion chamber design when I sould have just made it semi-hemispherical?" I do love it when the kid in the Durango commercial says "Heamey," tho...
    1994 530iA Sold
    2003 FX-35
    1991 MR2 Turbo
    Benneton (United Colors of)
    Default speak of the devils.....
    the reliable folk at howstuffworks has prepared a page on how hemis specifically work
    http://auto.howstuffworks.com/hemi.htm
    looks like mercedes has been rubbing off a little hard on the chrystler end of things......the article says that the new hemi has 2 spark plugs per cylinder.
  1. Brake Pedal "Tapping"/"Knocking" Sound - 89 535i
    Last Post: 10-16-2007, 07:12 AM
  2. "Trans Program"/"Limp Mode" Redline a Engine?
    By JMI in forum 5 Series BMW
    Last Post: 06-12-2006, 10:51 PM
  3. Replies: 5
    Last Post: 01-09-2006, 01:48 PM
  4. Replies: 10
    Last Post: 09-28-2004, 06:19 AM
