Results 1 to 10 of 11
Thread: No Heat
    Default No Heat
    The 525iT is running low on heat with the drop in temperature here in the northeast. The cabin filter is new so I have airflow. The aux. water pump sounds like it is spinning. I'm suspicious of the heater valves. I heard that they should click but I'm hearing nothing. I've tapped them to try to free them but still not luck.
    Are there rebuild kits available or do you just replace them.
    Warren Brown
    91 318is
    95 525iT
    Default obly the old ones were repairable
    rough price for a set is about $ 120,--. Replaced the ones on my car and the aux water pump some months ago. Worked 16 years w/o problem but they were due for retirement. I disassembled them after replacement just to check the inerts.
    Remove the wire plug from the top of the valves, If they have no power, they should be open fully. If so, the valves are o.k, and you have to look for the control panel or the control module.
    here some info on that
    Nov 2004
    Winston-Salem, NC
    Quote Originally Posted by WarrenBrown
    Warren Brown
    91 318is
    95 525iT
    My 525ia has almost no heat.
    My problem is a failed t-stat. Apparently, BMW engineered their t-stat to fail wide open (kudos to them) instead of failing shut (like GM, Ford, etc...) the result is your engine won't fry out, but it also runs cold. The heat is drawn from the warmth of the coolant, so colder coolant=less heat in the cabin.
    My engine gets out of the "blue area" when the temp is above 55 or so. When it's 70 here I get all the heat I want!
    I don't know if this is your problem, but figured I'd share what I know.
    -ashley
    Paper Gaskets Suck!
    Default Sorry Ashley , they fail closed just like most other
    thermostats but frequently they break like this which is the same as failing open
    Quote Originally Posted by acyre
    -ashley
    Nov 2004
    Winston-Salem, NC
    [QUOTE=Bill R.]thermostats but frequently they break like this which is the same as failing open
    QUOTE]
    Bill, Thanks for setting me straight. I was regurgitating what was told to me. So, I guess my t-stat really IS broken
    -ashley
    Paper Gaskets Suck!
    Nov 2004
    Winston-Salem, NC
    Being a guy that really loves to know how things work, could you or someone explain how the t-stat works mechanically.
    I understand the application and theories behind it, but fail to see how a spring loaded valve decides when to open and shut. What expands/contracts to open and close the valve? Why do they fail? How do the builders determine the degree or opening temp of the t-stats?
    -ashley
    Paper Gaskets Suck!
    Lincoln, NE
    Dip one in a pot of boiling water for a minute sometime. Kinda cool.
    It's a matter of expansion rates of certain metals at certain temperatures, IIRC.
    Default No, actually its because that there's parafin wax in the cylinder in the
    middle in a sealed chamber with a ram like a hydraulic cylinder.. when paraffin is heated or cooled it expands considerably causing the ram to move and open or close the thermostat... On a side note the newer bmw's now have electric thermostats...
    Quote Originally Posted by Mr Project
    Lincoln, NE
    Really? I cut a thermostat open a number of years ago and there was no wax. Of course, who knows what car that was from....or if the wax had somehow leaked out or something at some point.
    Default They frequently fail because they lose their wax.
    1
  1. Heat help
    By johngo1 in forum 5 Series BMW
    Last Post: 08-25-2007, 09:34 AM
  2. Help! I have no heat.
    By goheel in forum 5 Series BMW
    Last Post: 12-06-2006, 04:38 PM
  3. -35c and no heat - HELP
    By AllGo'n'Show in forum 7 Series BMW
    Last Post: 11-29-2006, 07:50 PM
  4. Heat All The Time=Heat Valves?
    By slupregime in forum 5 Series BMW
    Last Post: 07-29-2006, 02:34 PM
  5. no heat
    By joehough in forum 7 Series BMW
    Last Post: 11-12-2004, 05:20 PM
