It certainly sounds like a warped rotor. Do you notice any unusual syptoms when not braking? What do mean by violent? I'm picturing you getting thrown around the passenger compartment- and if that's the case, there's more to it than just rotors. Your calipers may be off spec. or worse.
The oem rotors and pads are decent and reasonably priced just about anywhere except the dealer. You could get the cross drilled ones for not much more.
If you want to upgrade- check out Bruno's faq on the subject. If you've never done it before, let someone do the work for you. Should be about 2 units of labor. Many good indies will let you supply your own parts.
