Results 1 to 10 of 12
Thread: Cupholders anyone?
    Default Cupholders anyone?
    OK, this may be silly but,
    I've been looking for a cupholder solution for my 530 which has none. I've seen three different types (two that are a press-fit into the center console), one that is a wire-type that attaches to the right of the console by the ashtray, and the flat flip-open types.
    Does anyone have any pics/opinions of what you have actually used? I'm interested in solutions.
    uberhahn
    '94 530i 5-speed. The work begins...
    Default Have a look here
    cupholders
    drinkholders
    ultimate cupholders
    I personally do not have cup holders. Need my hands to enjoy the drive
    Nashville, TN
    I went to Murrays and got one of the el-cheapo cup holders that you normally slide into the window channel. It sits on the floor and the flap that normally tucks into the channel is tucked into the center console. Basically its a version of this guys idea:
    Derek A.
    90 535i 5 Speed - Style 5 17"
    Apr 2004
    Reston Va
    I am using Mike's Ultimate Cupholder and it works great. Its the best implementation. I went throught the flat fold out job. Looked at the Wire Job; and Had the Plastic Foam injected dealie that fits in the center console. The Ultimate is the best I think. - JT
    Johntee540
    1994 540/6 Black - Tan - 199k
    Aug 2004
    South Atlanta, GA
    I use the cupholder that slides onto the edge of the center console. The plastic one that you can get at the dealership. I had problems with the thing tipping over with a drink in it if I went through a corner too fast. I used some black electrical tape on the inside of the groove of the cupholder to make it fit tighter on the center console and no more tipping over and you can't see the electrical tape. Only downside to this cupholder is that you can not fit a 20 oz bottle in it.
    Lexington, Kentucky
    Default Same one I use - works OK for cans, not cups
    I occasionally use one of the holders to hold my cell phone. I use the cup holder in conunction with a dealer purchased tray which fits on the front of the console which also works with cars with ASC. It holds my garage door opener etc. Together, I have fairly flexible space without stuff sliding around.
    Quote Originally Posted by spddmn713
    Mar 2004
    I had the same problem with that cupholded, after removing it to find an answer I noticed there were wear marks on the center console wood where it used to be on my 540i. It has since been removed.
    I currently just wedge my coffee cups in the holding area right next to the hand brake. Almost every coffee thermos style cup I've ever seen, fits there pretty good. The sides flex about a 1/2 inch and really keep the cup from moving. It's also a good size for a soda can. The down side is, it's not that easy to remove or put in. But I only drink at stoplights anyway.
    Miami Lakes, FL USA
    Default These work great......
    I bought one of these for my E34 and it was a perfect fit. When I sold the car, I mistakenly left it in the car for the new owner, but I bet they are happy I did. It removes quite easily, and in the photos from the guy's E-Bay ad....he even has it holding a Tom Horton's coffee cup!!!! What more could you ask for??
    I have no stake in this guy's product....it just worked great for me!
    Cupholder
    Good Luck........
    Brian C.
    There is nothing worse than a brilliant image of a fuzzy concept. -
    .............Ansel Adams
    Apr 2004
    Reston Va
    That one wont work if you have ASC. Otherwise its perfect. -JT
    Johntee540
    Hasn't anyone ever told you not to drink and drive? I wont take anything in my car that dont have a screw top to make sure it dont spill.
  1. Herb's cupholders are available again
    Last Post: 09-16-2011, 01:11 PM
  2. armrest with cupholders - not bad and cheap
    Last Post: 12-24-2006, 11:07 AM
  3. anybody using these cupholders?
    Last Post: 12-10-2006, 10:36 PM
  4. cupholders in e 34!
    By Paul in NZ in forum 5 Series BMW
    Last Post: 10-10-2006, 12:07 PM
  5. armrest with cupholders - does that fit?
    Last Post: 08-01-2005, 01:35 PM
