Results 1 to 5 of 5
Thread: question on rear brakes
    Nov 2004
    Default question on rear brakes
    could the rear rotors on my 540 be resurfaced or do i need to get new ones , just checked the pads and they are about gone , i've done the fronts twice and got all new parts but the rear rotors look still pretty good , any recs on pads and rotor brands and where to get them. I'm also getting new tires next week stock size 225/60/15 and was looking at the yokohamas AVS DB S2 , read a lot of good reviews on the tire rack web site anybody runnig on this tires?
    Default With Bimmers you buy new rotors and pads....
    Ate or Balo are OEM discs. Pad types are really dependent upon how you use the car and is a very subjective subject! You will get a myriad of replies saying XYZ pad is great....do a search!!
    I have EBC RedStuff on mine and Balo rears....YPYMAYTYC
    One thing though, before the job, buy new screws and hardware and also when you do your rears check and adjust your parking brake shoe adjusters.
    "Uncle" Phil C
    2011 Kia Optima EX-P.
    Former owner of a 95 525i 5spd. "The GQ" aka A Shark in sheeps clothing
    03 R1150RT 6spd. "DaRTth"
    00 R1100R 5spd. "LeRoy"
    Minnesota
    You can have the rear rotors checked for spec and if still enough material you can have them ground/resurfaced. I did this on my 325iC and have had no ill effects on both fronts and rears. cost about $10/rotor. New oem rotors are not very expensive, so, many will understandably just get new ones.
    Meridian, ID
    I usually run two sets of pads on each set of rotors. If you have a very noticeable lip on the distal edge, just replace. I never resurface, just replace the pads. Never had a problem. BMW rotors are pretty inexpensive, about a buck fifty should do rotors and pads and you will need one sensor.
    Mike Holbrook
    Meridian, Idaho
    Wichita KS
    Check the thickness of the rotors to see if they're within spec. If the thickness is within spec and you have no real ridges in the rotors, you can put in new pads without refacing the rotors. New pads will bed into the surface of the rotors OK.
  1. rear brakes not working
    By aquapool in forum 5 Series BMW
    Last Post: 03-03-2009, 04:09 PM
  2. Rear brakes click
    Last Post: 12-03-2007, 10:31 AM
  3. E32 750 rear brakes on E34 Bruno??
    By mholbrook in forum 5 Series BMW
    Last Post: 07-02-2004, 01:01 PM
  4. Rear brakes locking up
    By mjfeeney4 in forum 5 Series BMW
    Last Post: 02-28-2004, 07:50 AM
  5. OT: Chevy truck rear brakes question
    By gale in forum 5 Series BMW
    Last Post: 02-16-2004, 09:39 AM
