Battery life and care
As the GQ doesn't get driven every day, I decided to use a Battery Tender Plus charger on her. I use BT's on both our motorcycles and also on the twin deep cycle batteries from my Motorhome.
My previous BMW battery (the original!) lasted 7 years without using a BT so, being impressed with that, I coughed up and bought a replacement BMW battery which turned out to be maintenance free! Anyway, I used the battery pigtail connector from the BT Plus and just ran it underneath the seat, just outboard of the RH clip. It only sticks out about 1 inch and isn't really noticeable. I then run the BT lead in thru the side of the rear passenger door and I just connect it up and close the door on it.
During our recent VERY cold spell, I used the GQ and I just disconnected the BT plus and started up the car as normal. Well, I can tell you that the difference is night and day...even at 2 above, it spun over and fired up like a champ!
So...you can find BT Jr's at $21.95 and BT plus at $39.95. Your battery will REALLY last for years and you will definitely notice the difference in colder climates!
"Uncle" Phil C
2011 Kia Optima EX-P.
Former owner of a 95 525i 5spd. "The GQ" aka A Shark in sheeps clothing
03 R1150RT 6spd. "DaRTth"
00 R1100R 5spd. "LeRoy"
