Results 1 to 5 of 5
Thread: Most likely coolant leak in V8?
    Sep 2004
    Default Most likely coolant leak in V8?
    I am loosing coolant in my 95 540i and it's getting worse. Just casually looking at the engine bay I can't find the leak. What is the most likely place for coolant to leak in V8 and not be visible?
    Jan 2005
    normally the leak is is below the inlet manifold or what ever you call it over there and because its a v8 you cant see it
    1989 e34 520i se, red, mint condition (original)
    pro mechanic "all cars"
    Jan 2005
    the header is the exaust so what do you call the inlet???
    Boston & Attleboro MA
    water pump or hoses behind the intake manifold underneath the coolant expansion tank
    Nashville, TN
    Here is what is common called the valley pan. Coolant seeps from the corners and usually runs down the back of the block.
    Derek A.
    90 535i 5 Speed - Style 5 17"
  1. Follow-up on my M50 oil leak & coolant leak
    By Dick Schneiders in forum 5 Series BMW
    Last Post: 03-06-2008, 10:51 AM
  2. Coolant leak
    By 52vincent in forum 5 Series BMW
    Last Post: 02-05-2008, 09:51 AM
  3. Coolant leak HELP ME PLEASE
    By aabdelhamid in forum 5 Series BMW
    Last Post: 11-27-2006, 08:51 PM
  4. Coolant leak
    By peterllo in forum 5 Series BMW
    Last Post: 01-25-2005, 04:02 PM
  5. Coolant leak (yay!)
    By Craig in forum 5 Series BMW
    Last Post: 06-23-2004, 10:58 AM
