May be some engine guru may help with this question. A neighbor friend has a Mitsubishi MF (Like a Galant but with fuel injection). Every time he starts it cold in the morning (remember cold here is about 18 degrees C) the engine starts but hesitates for about 6 to 10 seconds, then normalizes and rise up idle. Start up fine every other time it is started along the day . Next morning will also repeat the story.
Is it not holding fuel pressure? Why does it along the day? Will a vacuum leak be solved so quickly after start? Temperature sensor may be, but solved in 10 secs? Your input will be greatly appreciated.
Javier
