Results 1 to 2 of 2
Thread: Parking Light/Turn Signal Question
    Mar 2004
    Gainesville, FL
    Default Parking Light/Turn Signal Question
    My passenger side turn signal won't burn. I looked at the harness, the bulb, checked it with another bulb the does burn, but still no dice.
    When I turn on my turn signal - it flashes. It just won't burn when I turn on my corner/parking lights. It trips the CPU warning when I turn on my headlights.
    Just tired of seeing the same warning come on day after day.
    Can anyone throw me a bone here?
    THanks!!!
    A Young Man with a Plan
    ericbendler@yahoo.com
    Nov 2004
    Default does the bulb you're using have 2 contact points on its base....
    The front turn indicator/park lamps have a dual capacity and should have 2 filaments and dual contact points on the base (see bulb in pic below). If the base only has one contact point...then it will only function in one capacity.
    (notice the 2 contact points on the base of this front turn indicator bulb...this is from my e38...but the concept is the same on the e34)
    Q
    95 525iT / 97 740iL
  1. Replies: 7
    Last Post: 02-21-2008, 02:48 PM
  2. Turn signal works, parking light doesn't
    Last Post: 09-11-2007, 02:04 PM
  3. Head light/Turn signal problem
    By Milkboot in forum 5 Series BMW
    Last Post: 12-11-2006, 02:45 AM
  4. turn signal bulb question
    By GoldenOne in forum 5 Series BMW
    Last Post: 04-22-2006, 02:28 PM
  5. Euro light and turn signal question...
    By bighc2000 in forum 5 Series BMW
    Last Post: 06-29-2004, 10:18 PM
