Results 1 to 9 of 9
Thread: Hy I´m new + lifter question
    Jan 2005
    Germany
    Default Hy I´m new + lifter question
    Hello,
    first off I´m from Germany so my grama is a little bad (half American but it´s been a while since i have had to write
    Anyway my M50 with vanos is anoying me with lifter ticking until it fully warms up (water gauge).
    Tryed different Oils (Castrol 10W40, Lubro-Moly 5W40 and Castrol RS 0W-40) and still have the same problem. But runs most quiet with the 0W-40 when warmed up
    Any clues?
    Greetz from germany
    edit: already used the search
    Toronto
    Default Nothing you can do about it.....
    My car sounds like a diesel when I start her up in the winter cold. Runs smooth but sounds tough. Once she is all warmed up you do not even hear the engine. My car has 205k kms on it and never had any mechanical problems with it.
    Brian 95 525ia M50 Vanos
    Quote Originally Posted by stormy
    Hello,
    Any clues?
    Greetz from germany
    Jan 2005
    Germany
    First off thanks for the quick reply
    Well when i bought the car it didnt have the problem (20tkm ago) it either startet when i changed from shel helix 5W30 to 10W40 ore when i dogt it right away going home from the dealer (oil warm) ore when i put some lifter cleaner in from lubro-moly and took it out after about 1k (have a slight ratteling noise while aceleration between 2k and 3k rpms but that is only heard when I´m going through town when the sound bounces off the walls of the houses. That´s why i put it in.)
    damn my grama must be bad lol
    Default Egads, dont be using oil addatives!
    are you using a synthetic oil now? If not I would recommend it, flows faster when cold even compared to conventional oil and a few people have claimed that it quited the vanos up a bit on startup.
    Jan 2005
    Germany
    The Lubro-Moly 5W-40 and Castrol RS 0W-40 are both fully Synt.
    I was thinking about trying out Motul 300V Competition 15W-50?!
    Default I run 15w50 in my 95 525i
    Can you get regular Mobil1 15W50? I run it year round in mine and do not suffer from lifter noise....
    "Uncle" Phil C
    2011 Kia Optima EX-P.
    Former owner of a 95 525i 5spd. "The GQ" aka A Shark in sheeps clothing
    03 R1150RT 6spd. "DaRTth"
    00 R1100R 5spd. "LeRoy"
    Default Stormy, there is a good forum in Germany
    for the E34.
    Probably you know it already. Just in case
    click here
    Jan 2005
    Germany
    @philbyil: nope cant get that type, just the ones from Motul but they are supposed to be very good to....
    @yep already knew that, just wanted to see how the "problem" would be fixed overseas maby theres a tip here to get me around the 24 lifter change
    Jan 2005
    Germany
    Got releaved from the tick *wheew*
    I put in Mobil 1 SAE 0W-40, and at first was worryed because the engine soundet like sh... now silent as can be, still ticks on some days more ore less but i would say that the M1 is doing some cleaning and that sounds worse at that moment
    took about 3tkm for it to quiet down, now after 5tkm it´s all good...will change after 7tkm more and then it should be perfekt
    greetz
  1. E32 window lifter repair
    Last Post: 05-01-2007, 06:06 AM
  2. Let me get this straight, lifter noise???
    By 525iE500 in forum 5 Series BMW
    Last Post: 03-29-2007, 01:29 PM
  3. lifter jack
    By Ariel525i in forum 5 Series BMW
    Last Post: 10-23-2006, 09:47 AM
  4. Thanks to Bill R., my M50 lifter noise is gone
    By Dick Schneiders in forum 5 Series BMW
    Last Post: 05-27-2004, 01:41 AM
  5. camshaft lifter ticking
    By molesz in forum 5 Series BMW
    Last Post: 04-05-2004, 10:22 AM
