Results 1 to 2 of 2
Thread: Rear Light Leak!
    Aug 2004
    detroit
    Default Rear Light Leak!
    my driver side rear light leaks water out of it when it rains, is this a sunroof thing, or a rear window seal thing or what? also randomly the other day my aftermarket radio cut out, not the power, but the speakers, so i have power, and can cycle though all modes, but i dont have any sound, anyone have similar problems?
    and on a final note, dose anyone have exhaust for a 535i? i need it bad
    thansk, you guys save my life monthly
    Kyle
    Probably you need a new sealing/gasket ring for the rear light.
    Sometimes it helps to tighten the screws or use some flexible
    sealing stuff to add to the sealing surface.
    As for no sound of the radio: would first check all cable connections for proper fitting and/or oxydation. Maybe spraying all contacts of these wires/cables with a good electr. contact spray may help.
    Sorry, I do not have an exhaust for you.
    But maybe you indicate in which area you live so that someone migt help or knows a boneyard where to get one.
  1. Rear Air Vents = Vacuum Leak?
    By AngryPopTart in forum 5 Series BMW
    Last Post: 12-31-2007, 06:35 AM
  2. 4hp22 A/T Rear oil seal leak... Help!
    By sneekens in forum 5 Series BMW
    Last Post: 12-20-2007, 07:16 AM
  3. 1989 535i (e34) Rear Oil Leak
    Last Post: 08-31-2006, 06:17 PM
  4. Rear main seal leak again
    Last Post: 03-30-2006, 11:11 AM
  5. Check engine light: O2 sensor or vacuum leak?
    By Bruno in forum 5 Series BMW
    Last Post: 03-13-2004, 07:02 AM
