Results 1 to 8 of 8
Thread: Removing Rear Struts
    Jan 2005
    So Cal
    Default Removing Rear Struts
    Hello,I'm new here.I have a 1995 525IT which needs new rear struts.I can't figure out how to acess the top mounts. The factory manual says to remove the rear side seat cushion which I have done but I still can't get to the top 3 nuts.The rear seat belt retractor appears to be mounted above the strut mount. How does the trim come off to access the strut? Thanks.
    Maryland
    I have photos of when I replaced the struts on my E34 sedan. Maybe they will help.
    I can email some of them to you if you like.
    the nuts are under the rear shelp, I just lifted it up and loosened them, someone mentioned that the shelf easily slides right out
    Maryland
    FWIW,
    The somewhat raw photos of the 525i Sedan rear arrangement can be found at
    http://danzee.angeltowns.net/SturutR...earStruts.html
    It sounds like it's alot easier on the Touring model!
    Dan
    Jan 2005
    So Cal
    Thanks for pics and info. The touring is not the same as a sedan so there is no rear shelf to remove. The seat backs recline so there is no need to take the seat out. I'm guessing there are some hidden clips or something holding the trim on the strut tower.I'm afraid if I pull on something too hard the trim will break, not come loose.I can take a pic but don't know how to post it.
    Default This should help
    Jan 2005
    So Cal
    Thanks,Bill.That's just what I was looking for. I think I'm going to like this forum.
    ahhhh the old touring switcheroo trick slipped by me.
  1. Rear struts-how often to replace?
    Last Post: 08-09-2008, 10:44 AM
  2. Rear Struts
    By karl1171 in forum 5 Series BMW
    Last Post: 01-16-2008, 11:59 AM
  3. Rear suspension struts removing -93 520iATouring.
    By tibbe in forum 5 Series BMW
    Last Post: 08-08-2006, 11:29 AM
  4. Problems installing rear struts
    By newlano in forum 5 Series BMW
    Last Post: 04-10-2005, 04:50 PM
