Thread: Brake and exhaust question
    Wash DC
    Default Brake and exhaust question
    I had my brake sensor come on two weeks ago. I changed the brakes but the message is still on. How do I get it to turn off. Also I'm in need of a new exhaust system can anyone make a recommendation. I think I need the cat converter also.
    91 535I
    Apr 2004
    Monrovia, CA
    The brake sensor is a wireloop that wears through and creates a broken circuit to let you know that the pads are about gone - you'd have to replace the sensor.
    I know on my Roadster, I had to replace the sensor and hold the key in the ACC position (position 2) for about 30 seconds for it to reset the indicator - I don't know if that is required on the 5's though.
    Can't help on the exhaust - sorry.
    Eric
    never re use the old sensors, the sensor could have a broken link inside of it even though it loos fine. Spend the $2 and replace both front and back. If that doesnt fix the problem than you have a broken connection in the wiring, probably right by the wheel well where it goes through.
    most likely it's a bad sensor, that car doesn't need to be reset like the 96 and up bimmers ("new" airbag reset will reset the brake warning in them) i think ether www.bmpd.com and or www.bavauto.com sell aftermarket cats that bolt up stock for a decent deal, shop around you may find better but that's a place to start
    Quote Originally Posted by dcbimmer
    91 535I
    Albuquerque, NM
    Default Re: exhaust & brakes . . .
    As a temporary fix, you can strip the old brake sensor wires & twist them together to get rid of the message. The sensors are on the inner pads on the left-front & right-rear wheels.
    Eberspaecher makes a good OEM replacement muffler, check the various on-line vendors that Shogun listed. Avoid Bosal & Ansa, they rust out prematurely.
    Bill R. posted an exerpt from the TIS awhile back about the test port pressure for diagnosing the cat, I think a healthy backpressure upstream of the cat is generically something like 1.5 psi or less. M30 cats last a long time, they rarely need replacing. I have 167k on mine & just passed emissions last week with very low numbers, with only a 10 or 15 minute warm-up drive, with an EAT chip, 19 lb/hr Mustang injectors, & a 3.5 bar FPR.
    gale
  1. 535i exhaust question
    Last Post: 05-28-2009, 09:20 PM
  2. Supersprint exhaust question
    Last Post: 01-21-2007, 07:05 AM
  3. 535/ M5 exhaust question?
    By Jake Casson in forum 5 Series BMW
    Last Post: 11-10-2006, 12:27 PM
  4. Exhaust question
    By dbals in forum 5 Series BMW
    Last Post: 08-24-2006, 03:06 PM
  5. Question on Exhaust
    By kick7ca in forum 5 Series BMW
    Last Post: 02-01-2005, 11:32 PM
