i had kind of the same problem until eventually the window completely fell off its tracks. what caused it was the lubricant that is on the tracks where the window motor moves has dried out, causing the motor to slip off the plastic holders thus causing the window to fall off.
easy fix, really.
take the door panel apart. get some graphite based lubricant. replace the plastic pieces.
that's all.
