Results 1 to 7 of 7
Thread: How important is the O2 sensor?
    Aug 2004
    Default How important is the O2 sensor?
    Hi All,
    I had a engine check show up and the error code it spews out is "1221" which is to do with the O2 sensor.
    How serious a problem is this? Can I drive with this thing on?
    Please tell me what is the best thing to do?
    Praveen
    baton rouge, loserana
    you can drive with it on. 02 codes are not allways the sensor itself, air leaks and bad tune up are common causes, out of adjustment/dirty throttle body can screw with it too
    Aug 2004
    Default Should I reset?
    So would the light go away? Or should I reset it and check if it happens again?
    I also heard that it is kind of a reminder, is it so for a 95 525i?
    I am planning to give the car a rip to get rid of deposits, is this a good idea?
    Praveen
    id check over everything for any obvious air leaks or any other problems and reset, that was much older cars that had 02 reminder lights, a good flog couldn't hurt
    Quote Originally Posted by unhygenix
    Praveen
    Aug 2004
    Thank you, I feel much better now. What exactly do you mean by obvious air leaks?
    My fuel tank cap was stolen 2 days ago, could that be a reason?
    Thanks again
    that could piss it off, air leaks as in cracks in the air boot or disconnected vacuum lines coming off of the valve cover
    Thanks again
    Aug 2004
    Default Thanks again, I will check it all.
  1. 16 important OIL questions answered
    Last Post: 05-06-2009, 06:30 PM
  2. A really important POLL
    By Kalevera in forum 5 Series BMW
    Last Post: 02-23-2007, 10:03 PM
  3. is the drip tray important?
    Last Post: 02-15-2007, 01:13 PM
  4. important!! steering wheel help
    By kyleN20 in forum 5 Series BMW
    Last Post: 12-08-2005, 08:21 PM
  5. A/C Aux fan...how important???
    By Guelphguy in forum 5 Series BMW
    Last Post: 08-19-2005, 10:47 PM
