Results 11 to 20 of 23
Thread: Light bulbs
    Miami Lakes, FL USA
    Default A picture is worth 1000 words Shogun. ; )
    And while I'm at it with the old sayings...
    "Experience is the best teacher."
    Brian C.
    There is nothing worse than a brilliant image of a fuzzy concept. -
    .............Ansel Adams
    Default o.k., here are reflectors after 100W bulbs use
    Nov 2004
    Winston-Salem, NC
    Default Here's a question for ya
    Yesterday, I go to change my foglamp bulbs to get rid of the check control message. After consulting the owner's manual and a "bulb book" at the local parts store, I buy 2 H1 bulbs.
    However, after pulling out the assembly I was somewhat surprised to find 9006 51w lowbeam bulbs. What the heck?!?
    Was there a big run to convert these bulbs after purchase? Or did BMW decide to change the specs and not reprint the manual?
    -ashley
    Paper Gaskets Suck!
    Bellingham
    Quote Originally Posted by aabdelhamid
    Does my sudden failure of the trun signals have anything to do with this ????? They work for one blink on one side and the right side is constantly lit ??????????? HELP ME.
    You've destroyed your lamp control module, or LKM.
    Sure you've got the OEM foglights? I recently changed my bulbs and they were H1's as expected....dunno....
    LOWELL
    Apr 2004
    I had problem with my lightw also and I tested the 100w bulbs (only for test not permanently!), the difference was extremely small, so then I put new HELLA lights, thats it! No more candle-light for me.
    Nov 2004
    Winston-Salem, NC
    Default I have NO idea!
    Quote Originally Posted by lowell
    LOWELL
    I have no idea if the fogs in my car are OEM. They have a brand mark on them, looks like NFL or NHL (N something L) same as the headlights.
    -ashley
    Paper Gaskets Suck!
    Bay Area, CA
    sorry to unbury the dead....is it too bad to run 65w bulbs? I.E. 9005's in place of the 9006's
    www.KaRealtySF.com
    My right headlight fixture is loose/broken after slightly hitting a deer. Any way to fix this or should I just replace it all? If I replace it what do you recommend? I would like brighter lights too.
    Edwin
    92 525iA
  10. #20
    Default maybe only the rubber bushings broken
    You can buy those parts for less than 1 $ I guess. If you touch the lamp and it is loose, usually the rubber bushings are defective or just out of place.
    You can also buy single items from the dealer. This pic just as info.
    click
    On this occassion you can also clean the reflectors and the glass from inside, light is much better after that.
    how to do
  1. OT: BillR LED light bulbs?
    By Tiger in forum 5 Series BMW
    Last Post: 02-01-2007, 12:47 AM
  2. DIY: OBC Light Bulbs - Make your own
    By stilljester in forum 5 Series BMW
    Last Post: 11-21-2006, 01:12 AM
  3. New bulbs=Light adjustment?
    By we_call_him_doher in forum 5 Series BMW
    Last Post: 06-26-2006, 08:46 AM
  4. LED Light Bulbs - Exterior
    By Qube in forum Electronics & Lights plus A/C
    Last Post: 07-08-2005, 11:47 PM
  5. OBC Light Bulbs
    By Mike Fox in forum 5 Series BMW
    Last Post: 01-06-2005, 11:37 PM
