Results 1 to 10 of 13
Thread: Yet another victim of Nikasil...sob.
    Default Yet another victim of Nikasil...sob.
    I just bought a '94 530i. 91k miles. Rough idle. No vacuum leaks. Bought for steal. Just took to dealer to investigate idle. He's doing the test today.
    I'm hoping for some positive news.
    -uberhahn
    '94 530i 5-speed. The work begins...
    Kingston, Ontario, Canada
    Default You mean "potentially" another victim?
    Ask for a hard copy print out of the leakdown test, then come back here. If he just does the diagnostics test through the DME, I wouldn't be so quick to send the car to the heap.
    How long has the rough idle been happening? With the colder weather? How doest the car start? Extended cranking, difficulty starting, etc...?
    Cheers
    Duey
    1995 540i/6 Sport Pkg w/E.A.T. chip and Nikasil injection Duey's Gallery
    sounds like a suitable candidate for a 4.0L transplant.
    The American thing to do
    George
    Austin, TX
    bored 4.4 liter, i smell a 4.6-4.8 stroker :-D
    even better
    Quote Originally Posted by DueyT
    Cheers
    Duey
    They're doing a full leakdown. I will scan and post here as I get it. The cold weather has really brought the prob out. Starts just fine, very little cranking. However it will not hold at idle. Stalls immediately without throttle input. As it warms, it gets better, but I still can't coast in neutral, or at a stoplight.
    uberhahn
    If it always did that for you, then Nikitis may be an issue.
    If, however, its undrivability/idleability only became unacceptable after the colder weather really set in, I'd be betting on a cracked inlet manifold gasket or the PVC plate...
    My 2 ¢
    Duey
    Apr 2004
    Reston Va
    The Cold weather Onset bothers me. I am betting more than $50 its a vacuum leak. PVC Plate or intake Manifold gasket. If it ran fine when weather was warm then no reason to expect a sudden onset of Nikititis. These things are often mis diagnosed. At this age these cars have more Vacuum leaks due to organic failure than block failure. Who wants to bet? - JT
    Johntee540
    1994 540/6 Black - Tan - 199k
    Cardomain Site: http://www.cardomain.com/ride/737181/1
    Toronto, CANADA
    My 2 ¢
    Duey
    Or it could be running too rich when cold. May need to change the coolant temp. sensor.
    baton rouge, loserana
    throw in a clogged cat on one side with a blown plate and they run real good, or a weak fuel pump. disconnect the battery for a few minutes reconnect and start it and see how it runs, if it is a leak it should run better
    Quote Originally Posted by Johntee540
  1. Victim of Flood, need help.
    By NoSpeedLimits in forum 5 Series BMW
    Last Post: 07-06-2006, 07:05 PM
  2. How to identifie a V8 Nikasil
    By clack in forum 5 Series BMW
    Last Post: 01-29-2006, 04:40 AM
  3. That old chestnut - NIKASIL
    By Zeuk in Oz in forum 5 Series BMW
    Last Post: 04-26-2005, 06:24 PM
  4. Nikasil???
    By Incantation in forum 5 Series BMW
    Last Post: 03-23-2005, 10:30 PM
  5. Nikasil
    By spitfire in forum 5 Series BMW
    Last Post: 06-20-2004, 10:55 AM
