Piece of cake. Get new radiator. Get two new rad mount clips (although I have acquired the art of removing them without breaking them, I put new ones on anyway). Drain system, Remove fan, remove fan shroud, undo the hoses (yes the AT cooler lines too). Pull old one up and out, drop new one down and in. Now reverse your steps. There aren't really any gotcha's. You need to take the fan off, because the shroud won't clear the fan on the reinstall, and if you try to force it you are apt to scuff up your rad fins.
It's an excellent time to change out water pump, pulleys, belts etc. as you have alot of room when the rad is out anyway.
