and it's not a LUMP!Originally Posted by ben wilamowski
This is very likely to be the profile gasket on the engine which is a known weakpoint on the M42 lump.Originally Posted by billb
Bill B.
95 525i
the housing oring or gasket as seen here...
I stopped by Ace Hardware last night and picked up a 24x3mm o-ring, and will try to source the gasket next week. 10-day backorder on the BMW o-ring...what's so special about it? Oddly, I could not see any leakage from above in that area, but it's really hard to see I suppose. I've definitely got something going on. Last year I replaced timing cover gaskets and front crank seal, so that should be pretty tight. I've been noticing some milkiness in the oil, but I saw that last winter, and it went away in the spring, summer, and fall (and I'm not losing coolant). I'll get to the bottom of this next week, I hope (off all week and temps might be in the 60's here).Originally Posted by Bill R.
Thanks for your advice, Bill.
Bill B.
95 525i
After owning the 525 for 6 weeks now all my problems are cold weather problemsOriginally Posted by wengenstein
Here's my list...
1) Fog Light message (bulb out and lens cracked)
2) Driver side low beam cracked
3) Slight oil leak (after wife confused brake and throttle while starting)
4) T-stat stuck open = overcooling = almost no heat in cabin
5) Leak in rear pass-side footwell (clogged tube maybe)
6) no smooth idle
7) nice whine when using the CD changer (cold temps only)
8) casette player eats CD Tape adapter
9) rock chips
10) rust spot below rear driver side tail light
And this morning...
11) turned on blower, squealing from dash (varied with fan speed)
On the bright side...
Love the car
Windows work
Doors lock
engine starts
tranny works
radio works (see above)
wife loves it
things could be worse, I could own a renault
-ashley
Paper Gaskets Suck!
They rarely fail and have a BMW logoOriginally Posted by billb
Best,
Rory
<Insert list of modifcations or clever saying here>
Of course, neither of my local dealers stock the parts, but the dealer 85 miles away have six of each...
I cleaned the oil pressure sending unit last night with contact cleaner, dried up the connections, and started her up. The OP light went out, then began to slowly creep back on at idle. I looked under the hood, and could see a stream of fresh oil coming from under the oil filter housing assembly. It was too late in the evening to begin dismantling, but that's definitely a prime candidate. Guess I know what I'll be doing next week...
Bill B.
95 525i
My oil filter housing leaks underneath, or at least, the pipes were oily. I just wiped 'em clean and moved the clamps up to the end of the pipes and clamped 'em down tight. At least so far, it appears to be holding, since the car never appears to lose a drop of oil between changes.
However, since I got the car in February, I still haven't checked the transmission oil... :-X
Ex-Calypso Red 540i owner
