Results 1 to 8 of 8
Thread: Well, brake system woes!
    Austin, TX
    Default Well, brake system woes!
    Apparently the Mintex pads i was shipped from BMA were defective, because they lasted a whopping 8 miles. I got to the 7th mile of the test drive, and the pedal went to the floor, i thought i needed to bleed. I pulled off the wheels to have a look, and the pads were down to about 15% remaining. New ATE Powerslots were installed at teh same time as the pads too. I then switched back to my slightly used RaybestosQS ceramics, after sanding them smooth of course. 45 miles later, and the pedal is still firm as it should be, checked the pads again and they're perfect. Did i just get a faulty set of pads or what?
    Aug 2004
    Did you take it easy the first 200 miles?? No hard braking whatsoever right??
    I've never seen a pad wear that fast.. was it both pads down to 15%?? I would have to say its the rotor / pad combo , Mintex are good pads but with slotted rotors it will just act like a cheese grater with those pads... (IMHO)
    Default but slotted is better!
    [QUOTE=an535i]Did you take it easy the first 200 miles?? No hard braking whatsoever right??QUOTE]
    of course he did.
    Austin, TX
    Quote Originally Posted by an535i
    200 miles? i made it 8 miles! and yes i took it easy. Also, this is what Yves recommended to me as a great setup, he uses them on his M3. I suppose this isn't a good combo on the 5!
    Default Youcall them yet? What did they tell you?
    Austin, TX
    Yves said just to box them up and send back. He's never heard of Mintex pads doing this, but it does happen.
    Default Dood take pics before you ship em off!
    Quote Originally Posted by bimmerd00d
    Boston & Attleboro MA
    LOL, Dad use to give me crap bout wearin out brakes & tires... will have to tell him you beat my all time record...
  1. Ventilation system woes.
    By Michael999 in forum 5 Series BMW
    Last Post: 11-30-2006, 06:24 AM
  2. Leveling System Woes?
    By ron kirk in forum 5 Series BMW
    Last Post: 03-24-2005, 09:46 PM
  3. ESD Regelt & Brake LT Circuit msg woes
    By tracye34 in forum 5 Series BMW
    Last Post: 11-04-2004, 02:06 PM
  4. Brake system Maintenance - DONE!
    By JoeS in forum 5 Series BMW
    Last Post: 05-25-2004, 08:23 PM
  5. Brake System Flush
    By JR'Z 525 in forum 5 Series BMW
    Last Post: 02-22-2004, 09:14 PM
