You're sure you don't have a hardened and cracked brake booster hose and a broken nipple on the check valve? I know I did.
so here I go again, this time the check light stays on and it idles really rough just like an intake leak. I drove 20 miles highway and while waiting for a light it came on. This occasionally happens but this time it didnt go away and the rough idle is present. Think it could be the PCP plate or the O2 sensor....hard guess I know but I'm open to any ideas on which way to start checking things.
Cleared codes by disconnecting/shorting cable leads, Idled smoothly. Went for a short run then got a 1213 code...same deal. Intake gasket? How many beers does that take?
When I got code 1222...Originally Posted by 632 Regal
Bill B.
95 525i
after I cleared the codes earlier I brought it home and then hear a quacking sound like a belt or something but was at the rear of the engine (cover on). I really think it may be an intake leak in this cold weather.
I had the same thing happen to me...I'm getting my intake manifold gasket replaced tomorrow...On the first day of real cold weather up here I was at a stop light. The check engine light popped on and suddenly I had a real rough idle...
'95 540i 6sp, uuc ssk, Dinan chip
proud member of the nikasil club
Check the vacum line to the fuel regulator. On my 540i, is was located at the rear of the engine. I "found" this when i accidently bumped the insulation and heard the leak.
