Results 1 to 10 of 11
Thread: e32: How to change power window motor
    in the link in the last post there it says:
    If you're replacing the motor only or need to take the motor off of the assembly for whatever reason, you'll need to connect the motor's cable (as the whole assembly is out of the door), then press the "down" button to move that cog wheel in a position where you can reach the third screw that holds the motor. Again, keep your fingers out of the way of the moving parts.
    the motor is help by 3 Countersunk head screws accdg to ETK http://bmwfans.info/parts-catalog/E3...chanism_front/
    https://www.buyautoparts.com/buynow/...z_ltYqkWh5436W
    BMW E32 front window regulator failure and replacement
    https://www.youtube.com/watch?v=EVZz0tPfxkI
    https://www.bimmerforums.com/forum/s...ator-it-s-easy!
    https://www.shiftbmw.com/model/e32/r...egulator-gear/
  1. Replace driver's side power window motor
    By AZ91525ia in forum 5 Series BMW
    Last Post: 10-08-2006, 01:52 AM
  2. Changing motor for power window
    By nsbone_1988_520i in forum 5 Series BMW
    Last Post: 12-21-2004, 07:48 PM
  3. Replies: 2
    Last Post: 12-01-2004, 02:58 PM
  4. Window Motor
    By mrbmw1 in forum 3 Series BMW
    Last Post: 08-25-2004, 06:45 AM
  5. Is window motor replacement a DIY?
    By chris530it in forum 5 Series BMW
    Last Post: 04-15-2004, 08:20 PM
